Hi there lads, just some advice needed about my rayco rg20hd, at the start of the job it fires up fine sometimes battery flat but starts with jump leads, clutch engages fine but after a stump i have the throttle locked on the handle but the revs drop about half and i struggle to grind anything, i dont know whether its the throttle cable stretched, any ideas or has any one else had this trouble?
many thanks hamdogg
It seems to be fine after i jump start it but dont see how it could be the battery that effects the throttle? but im not that mechanically minded!
It's likely the starting and throttle problems are unrelated
The revs dropping off may well be a blocked fuel filter[/QUOTE]
My first thought, check the inline fuel filter.
