Help working out a area
Jimbob87
Hi need help again with an area we have to turf. We have worked it out but want some confirmation as its a big area and dont want to get it wrong.
I have broken the area into 3 differant areas
Area 1
Top side 5m
side 1 5m
side 2 4m
bottom side 5m
Area 2
Top side 22m
side 1 22.5m
side 2 13.5m
bottom side 12.5m
Area 3 is a triangle
side 1 26m
side 2 25m
side 3 18.5m
Hope someone can help got to get it priced asap for a customer of ours who found 30 cows paddling round on his lawn:thumbup:
Many thanks James
Area 1 - 22.5 sqm
Area 2 - There is no generalized formula for calculating the area of a quadrilateral given just the sides. You would need to specify at least one angle to make the answer unique.
For example, let's take a quadrilateral with all sides = 10. Now if this was a square (90 degree angles), then the answer is obviously 10² = 100 sq. units.
But a rhombus is also a valid quadrilateral with equal sides. A rhombus with sides of 10 would have a smaller area, than the square. In the worst case, if it had tiny angle and a really big angle, the area would be close to zero.
So unless you have a known angle, or perhaps a known diagonal (where you could calculate the area of the two triangles), there is no way to figure the area of the quadrilateral just given the measurements a, b, c, d for the sides without a diagram or angles
Area 3 - 1/2 base* height = area of triangle for right angle but doesn't sound like it is so would also need an angle to work out the area of an uneven triangle...
and that is with 3 bottles of big cider in me
that'll be £5.27 please for the 3 mins i've just spent writing this post:lol:
I beg to differ. Jimbob has measured all 4 sides, giving top, bottom and each side. He just needs to measure one diagonal then use this calculator Area Calculator
And the triangle is easy. Given 3 sides there's only one way the sides can be in relation to each other. You can draw it to scale using a compass and graph paper, then split the one triangle into two right angle triangles and measure area of each. Or use http://www.handymath.com/cgi-bin/irregangle12.cgi I calc the area as 219.48782 square metres.
£10.80 please Jimbob
Oops, sorry Rob - just seen you mentioned the diagonal of the rhombus!
Edited by Pedroski
As area 1 is also a quadrilateral and you only know the dimentions and no angles or diagonal then you can not say the area either so give back your fee please lol :001_tt2:
Ah but i know 3 sides are the same, so nearly a square...
5x5 = 25 sqm
but one of the sides is 4m, so if you took the area as (4x5) + (1x5/2) = 22.5 sqm
£2.50 then!:biggrin:
Area 1 is easy. Because 3 sides are the same and the 4th is only slightly shorter, then it's not far off the area of a square.
Rob - beat me to it.
Edited by Pedroski
Rob posted just what I was going to say!
