I just wondered if I could ask for some advice on branch walking. Ive been climbing for a few months now (not regularly) and i struggle when it comes to getting far out on a limb. I cant seem to get my head round it, i dont no whether its just that my balance is terrible or I fear of falling and swinging into the tree.
Is this just an experience thing?
Anyone else had this problem in the past or has any tips?
  • Replies 36
Well- depends on the tree and yr confidence. Make sure yr anchor point is hi as poss', use a sling to jib out yr rope from an upper branch if poss' ( redirecting ), remember u shldnt hav more than a 2m pendulum if you slip -an a sliding bridge on yr harness means reaching out is easier. Don't worry about caterpillar'ing out a bit, I do,
K
Get your anchor point as high as you can and try to put plenty weight on your rope rather than just balancing, If your main anchor is slightly to one side of tthe branch that makes it easier. TBH though after a while you'll notice that your balance just improves and you'll forget you ever had this problem.:001_smile:
practice! i wouldnt worry about redirects for now, just keep your weight in your rope, lean far foward(in direction of branch) have one hand releasing your rope, the other infront of you, grabbing branches,the branch for stability.
if you get to a point where youre nerves are going, just think whats the worst that could happen? - a slip? a swing into the tree with a little bump?
oh and use a friction saver-nothing worse than having a tight rope!
just takes time really, soon you'll be running along!
Sorry forgott abt frictionsaver -use a VT +pully too, much nicer one-handed
remember your head is the heaviest part of your body, if you are using a prussik dont have it too long, i always have a really long one for getting up nice and quick, but it is a hindrense when branch walking. but if you are bricking yourself you will be fine.
stick in there and as the other guys say it will just come together.hang in there mate.
