I'm running a 13hp Honda gx with a 72lpm / 3000psi dual pump and 75litre hydraulic oil tank.
I currently use a 10tonne ram, so it had a very fast cycle speed and enough power to split most discs. But i know it would also comfortably power a 20tonne ram.
The pump, engine, tank, fittings and pipe cost me £1200 all new.
I am here: http://tapatalk.com/map.php?n34q4g
Have you any pictures?
I'll take some more pics tomorrow for you, can also put you in touch with the company I got all the main bits from.
Cheers, we currently run our splitter of the tractor but would be better if it was stand alone, as the tractor could then do other stuff!
Don't forget if you are changing to a stand alone engine, keep the tractor hydraulics so if the engine fails you can still work the splitter with the tractor.
Would get you out a jam.
im in the process of making my splitter independant, im looking at a donkey engine and pump off a readymix truck.... has anyone any other words of wisdom? valid point leave it that it can be used by the tractor as a back up
