I have made candles by splitting part way then holding split open with small stick. Quicker than sawing
i like that idea, i make up quite a few candles and it always fcuks my chain right up! gonna try that tip, cheers
I find saws wont cut down a ring(only makes sawdust), so cut in line with the grain as if slicing up a big thin ring (produces saw straw), maybe drop the rakers a bit.
Should make Swedish candles no prob, sure that's the way they do it, you will fill your Volvo in Abba-out 1/2 hour:thumbup:
My chain sharpening is not the best but not had a problem cutting candles or with the grain. Worst problem I seem to get is long stringy bits clog saw. I tend to hold a few inches out of cut and not pressure on saw so the strands break up a bit.
