Strimming.
woody paul
Took on a strimming job for a good customer because the chap that has done it in the past has got to have a opp. I got some sawtec which I have used before the other day and its rubbish just shatters:thumbdown: So what is the best on the market in 2.4mm.
techni 280, nylium or duoline all from Oregon, one tip is to hydrate line keep wet before use as polymers dry out hence go brittle and snap quicker than when normal.
Or try techniblade using a jet fit head which also takes any line as well
