I might have already posted it earlier in the thread, but if not, have a look at this guy's book and DVD's Dean. The book seems pretty good and his way is more aimed at the commercial build where you might be working with green timbers and a lot of it's done using powered tools to speed the job up.
Learn To Build Handcrafted Log Homes
I still really want to go down this route one day - probably end up building a full scribe shed in the garden and that'll be it :laugh1:
I work with this guy...
http://www.wild-furniture.co.uk/
Does it the proper way.
Looks some lovely stuff on his site.
There's a huge bench outside the Reindeer centre near Aviemore that looks like it could be one of his.
Edited by Chris Sheppard
  • Replies 154
I am a little dubious about log homes like that. Without significant amounts of insulation, they aren't going to be warm or comfortable. All the advertising shots show exposed timber internally, but the u-values for an uninsulated wall are poor. Even fully insulated it could be better.
Interesting timber construction technique that is finally just starting to be used in the UK is Brettstapel:
Brettstapel Construction
My wife's practice have done the only two buildings so far in the UK, but it's widely used on the continent. Advantages are that it's U-values are superb (down to 0.13), air tightness is unrivalled (went up for the air tightness test on Acharacle Primary school and it was 38 times better than regs stipulate - building regs in this country set a very low standard) and it makes use of low grade timber that would otherwise not be suitable for construction (Sitka - 47% of Scotland's forests are Sitka).
Just food for thought. We will certainly build our own house at some point (architect and sawmiller - it's inevitable!) and it will certainly be timber. I just don't think that log home style houses are the way forward because they don't put forward the idea that wood is a modern building material, something that I think is key to widescale timber construction.
Jonathan
Do you know much about the manufacturing/prefab process? What kind of accuracy is required? Do the panels require manufacturing at one of the Brettstaple plants using the future, or can they be constructed locally with small scale machinery and a little ingenuity? And if so, are there any examples of this in the UK. Question, questions! Have lots of spruce coming of age, but it's very expensive for us to move in about from where we are remote NW scotland. Cheers.
  • 2 years later...
