Tip: Marking wet wood for milling
morten
Everyone that has tried to mark freshly felled timber for milling with a normal graphite pencil, will know that the makings are very difficult to read :thumbdown:
However, Stabilo produces a special-purpose pencil, that will mark wet surfaces (and plastic, metal etc). The most commonly available color is black, but it is produced in multiple colors, and I frequently use the red color.
It is called Stabilo All 8008, see STABILO All ? PRODUCTS ? STABILO.COM
It costs about £1/pencil, and is sold in cartons containing 12 pencils. A Google search reveals this UK supplier: http://www.tigerpens.co.uk/acatalog/Stabilo_All_Pencils.html
Edited by morten
I don't mill (yet?!) but for timber frame construction I use a sumitsubo, it's the Japanese equivalent of the chalk line but uses ink rather than chalk.
It gives a far crisper clearer line than chalk and is easier to apply and read on wet timber.
Good call on the pencils, used to have some German ones that had black ink mixed in with the graphite and they would mark in any conditions, again lovely and crisp. Can't remember what they were called though...
I tend to use a builders chalk line, especially when setting up the rails for the mini-mill. measure one end hook the string, pay it out measure other end, pull tight then ping the string and you've got a nice straight line.:biggrin:
Funny it's called a ping line. But does it work when wet?
