Can you get in a mesh sack and dry it in that? Would make great firefighter then when dry.
Hi Rob,
Thats a thought, but I have tonnes of it and would love to find a way to brick it and burn them instead of my saleable logs.
Regards,
Doug.
WEIMA UK: Briquetters
Can see it being viable for own use, looks a nice neat machine that can be filled and left to its own devices. Max MC is 18% though, cutting firewood your sawdust is likely to be at least 25% as it comes off the machine.
There are a number of home made presses., search google.
A
We have both a briquette press and a wood pellet press which will both handle sawdust but for briquettes it needs to be less than 15% MC and for wood pellets below 12%. There is a great difference in quality of product produced but even the cheapest will produce a product for your own fire for approx £10k for briquettes or £20k for wood pellets. For commercial quality its more like minimum £40k for briquettes and £60k for wood pellets.
gather up your empty cardboard fruitjuice cartons, pack the sawdust into them, add some waste veggie oil(residue from proccesing wvo for the desiel engine in the mog) stand for a few days to let the oil soak through, add to fire......enjoy the heat......simples
When I did quite a bit of research on making pellets a few years ago I visited a pellet plant near Grantham. They chipped willow coppice with a heavily modified John Deere Forage harvester, they stored it in heaps for 6/8 weeks when it was dry enough to grind put through an integral drier in the plant and pellet. From that I would guess that sawdust would be dry to 18% in a few weeks if kept as firewood, ie undercover with wind blowing through.
A
A
Unfortunately you could not be more wrong. Sawdust does not dry out unless provided with forced air like a grain dryer. This is why we turn our timber into split logs and get the moisture content down to the correct level using a solar kiln before chipping and putting through a hammer mill. The alternative which they do with the willow you refer to is to artificially dry it which typically costs upto 30% of the sales price. We dont consider this practice to be economic.
