Using Red Diesel for a Unimog
chrisgilltreesurgery
1st thing, is it registered as an agricultural machine.
2nd, are you doing FORESTRY work, NOT arb work, rules are quite clear here, no grey areas, if you only collect from roadside, no, but if you actually enter the "forest" to retrieve your timber , then yes
3rd, you are restricted to the distance you can "take goods", but there is no limit on the distance you can "collect goods", weird one that?, and
4th, you can deliver, and collect from a dealer, or repairer, no limit on distance.
with a carefull "interpretation " of the rules you can run on red as long as you do "forestry" work, just make sure youve got your story right and double check on the hmrc website, and print a copy off to keep in the cab, just in case your stopped by an overzealous idiot, you shouldnt have a lot of bother up here though
