Strange place to put yours, did you have a hole in your trousers Dan?
My wife refuses to stitch ours on, and I dont ever sew, so there are 4 more up for grabs if you have any other holes to repair:biggrin:
Lmao cheers barry👍 thinking of putting one on the left leg above the map pocket. Just put it there so it would last longer, and not come off or get as dirty if it was on the front.
But hey any free publicity is good publicity rite ! Lol
Well if you're giving them away, you could send a couple my way. Fancy making a key fob out of them.
I had a surpise gift arrive in the post this morning.
It was sent to me by a fellow Arbtalk member, and has now taken pride of place in front of my Aspen display in the shop.
It is totally unique and we think its great.
Thanks Dan!
Thanks Dan!
[ATTACH]147458[/ATTACH]
[ATTACH]147459[/ATTACH]
👍 enjoy barry 👍
This plug has come out of a Tanaka hedgetrimmer run on Aspen. It is used heavily enough in a domestic situation to need a sharpen every year, and this plug was put in a year ago.
Just shows how clean Aspen burns.
Putting the clock to good use for my advertising Dan.
[attach]147725[/attach]
Should of charged advertising rights lol
Classic sign though
Edited by Dan Earp
I would like to use aspen, just for the fact of wasting fuel that's gone stale, I don't use my 2stroke equipment day in day out, just now and again.
Is there any changes you need to do to the machines?
If you use aspen can you chop and change back to mixed fuel?
Thanks
David
Thanks
David
If you use Aspen2 you may find that your engine will idle slower.
Adjust the (LA) screw in to get engine to idle at factory speed.
You may also want to adjust the lower range mixture screw to give more fuel if the engine is not as snappy as running pump fuel.
(L) screw unscrew 1/8 of a turn.
You may not need to do any of the above and if you did you would need to reset if you returned to pump fuels.
This only takes 30sec to do!
Please call me 07568 108953 or email [email protected] if you need and help or just for a chat.
Kind regards
Eddie
