Landrovers are ace thread
Hodge
  • Replies 44
Well landy haters
I pressed the wrong button.
My landy has been the dogs balls today, had to get a large dougie fir root plate and pole tjat the owner had stripped back in its hole today, it was at a funny angle, the owner had tried to get it back in with a car jack!! It bent before it could lift! I attached the strop at about 10ft and cut the other 40 ft off, it didn't spring back as some can, we then winched it with the landy super winch and pulled, it slowly pulled the root plate back into its hole. I then felled the butt and logged it up and split it with my axe. Richard my assistant logged the other section of fir and felled some windblown connys.
It was a fun day for once. Paid and away by 2. The landy saved the day again as the job was in a boggy field with no tirfor anchor available and narrow acess. The landy earned its keep again:)
Ours has just failed its MOT... :thumbdown:
Crack in chassis, Corroded brake pipes and a split in the side of one of the tyres!
Yeah but it will go most places and tow loads and carry
Woodchip and get in tight places with narrow access and is British!!!!!!!
