As anyone ever thought of trying to convert a old forklift into a logsplitter what was your views on giving it a go could it be done ???? some have spare hydraulics 3rd lever hydraulics levers unused etc
I guess it could be done. It's a heavy bit of kit to move around if it needs to go one site and the old forklifts I know are always really smokey. Might need to work down wind.:001_smile:
i was more thinking off a fixed peice of kit on my plot so to speak and suppose could fit a longer exhaust but would the hydraulics be upto the job i know all the steel is very heavy duty has anyone tried it ???
I assume that you intend to use the forklift ram as fitted, so a 3 tonne forklift will give you 6 tonne force if you disconnect the chains and use the ram force direct, which I presume you would.
Obviousely need to remount the ram upside down etc etc,and provide a guide to keep the blade running straight as the existing fork guides wont suffice for this usuage, I know what I mean but its a bit garbled in the typing
cheers
The pump, and engine (if good) would easily be up to the job, but...
Even the most knackered fork-lift (which will likely have a worn pump and engine) will cost a fair bit, just due to the fact that they weigh so much(scrap). If you can find one with a decent pump and engine for less than £1000 I reckon you're doing well., then you'll have to spend a fair while converting it to how you want it to work etc. That £1000 could buy you a reasonable part of e decent, purpose-built, tried and tested log-splitter.
thanks it was something i just thought could be of use to someone with a forklift truck but was only a pie in the sky sort of thing as you say it would cost a lot of money
i just wanted your views on the idea and why anyone had not used one etc as usual some more useless rubbish in my head lol thanks anyway for your advice
for £1000 youd get a very good properly made splitter, we got ours for £500 off ebay, needed a few modifications, but split 25 cube of dry logs last week, a lot of it was hard beech.
If you really need to use a splitter you can use ours here. or even come down and have a look at it
thanks rob thats very kind of you to offer me your help i will come down and take a look soon thanks i,am in no position yet to contemplate anything at the moment i,ve even lost geoff lucks boots in the post he gifted to me i feel really guilty now as everything i seem to do goes wrong please let me know your contact details so i can come and look at your log splitter please one day as i would like to meet up with you thanks hope you dont mind all the bother me troubling you i feel like i,am putting everyone out at times
i,am very very greatfull to you all for your advice and input
