346 xp chain
brewpup
I could be wrong but I think the 346xp in the US can be sold with a 'narrow kerf' bar and chain.
This means the bar is 1.3mm and not the usual 1.5mm and runs a different chain.
There should be some numbers stamped on the chain and bar which will give clues!
got old chain box it has measurements on that say .325 .050"/1.3mm. which is slightly diff to what timbercutter says .but would that size be ok.only 0.2mm out but me being a builder same village is normally ok.
1.5 would bind in the bar. Follow Rob's advice and look at the bar for the info. :001_smile:
