Yo,
If I was to store a small amount of logs, certainly less than 5m3 in my garage with a view to selling them in net bags in a year or two, what would be the score with business rates? I'm already registered as self employed for the odd day I help out my mate, just I ended up taking a load of maple and sycamore home from a job. Only thought about the potential for business rates after.
Don’t worry about the non domestic (business) rates, they can only charge you that if the property is a commercial one.
IF you should be concerned it would be from planning for change of use but they are your logs, and you are having a wood burner fitted,……….as soon as you can afford it
your only problems are peeing off the neighbours using chainsaw a bit much.
Otherwise would have thought a garage unless well ventilated not the best place to store.
Like someone said- if council get involved they are for your personal use
Business rates only kick in over about £5000 Rateable value
Best thing you can do really is to ring up the cords on site before coming home
Yeah, with regards ringing up, got it out the way in one foul swoop. Trying to get all rings split and stacked asap. I totally forgot I'm getting a burner installed next year!
