Ive not seen a pto driven one . But we use a hyd one that runs off the tractor hydro pipes its 15ton ram and a valve so pretty basic really . Works great ive just bought some longer hoses for it so i can use same tractor for the processor and splittes at the same time . Sorry to go off topic . Steve
Would this not be a tractor linkage mounted with a PTO driven integeral hydraulic pump on the splitter, i.e. self contained hydraulics?
Its a lot faster than using the hydraulics off most older tractors.
I think this is the set up for a lot of the semi professional/professional stuff?
Cheers
M
Cheers
M
thats what i am after, we have a david brown 780 with temperamental hydraulics.
I have a 10 tonne splitter driven from either the tractor hydraulics or a separate pto pump. It works far better on the PTO pump.
I also have a 22 tonne splitter that has its own PTO pump built in. Great machine.
Got the thor magik 13ton (pto) as well. Its a vertical splitter, with a two speed auto return ram. The oil reservoir is built into the main housing of the splitters mast. Its got dual controls, but you can use a single lever initially to wedge your billet/block in place under the blade before you engage full hydraulic power (leader control system).
I run it on just over tick with an old 35x, the shearing power through knots is very impressive. Great piece of kit, very well built, simple and reliable.
