i have seen a prouduct that is heated and wrapped around the post wear the rot normaly get,s them above and below ground level have to see if i can dig it out
down here they are called a post saver. heat shrunk plastic wrapper for the post
  • Replies 27
Can anybody help out there?
A fencing contractor friend of mine requires 1000 4-5" TD 5'6" long fencing stakes for a coast path job. The problem he has is now that the powers that be (in their infinite wisdom:sneaky2:) decreed that the active ingredient in tanalised timber (arsenic) could no longer be used, stakes are barely lasting 3-5 years before rotting off, this is not acceptable at the best of times, but especially not on this particular project.
Are there any suppliers (in the UK preferably) who can supply a product that will give at least ten years, as used to be the case?
Ta.:001_smile:
thers them plastic post , reclaimed stuff :001_smile:
Thats the stuff, not very good if driving posts in hard ground or stony conditions because can damage the sleeve. A lot of people (farmers) also just use normal tanalised timber and old engine oil, creasote mix, make up a 45 gallon drum full and fill with posts till it soaks right through.
Aaron
Ta.:001_smile:
Use stakes made from Larch, they'll last for 10 years. Untreated.
