Can any one recommend any ramps suitable for putting a pedestrian stumpy on the back of a tipper ?
They probably need to be about 3m long and fairly robust.
Thanks
Thanks
I use some steel ifor williams for my rayco 1625, they will last forever, pricey but you only buy once.
  jammydodger said:
I use 2 ladders with planks bolted to the rungs. 10 years with no probs and I dont have to worry about them getting nicked :thumbup:
Probably a better idea:001_smile:. Especially for a lightweight grinder,
cost buttons aswell.
Thanks for the replies , but does anyone know how we'd stand legally if an accident happens while using home made ramps
I've used scaffold boards alot myself and have seen them slip off the truck a few times so I thought buying the proper kit may be a good idea.
Sent from my iPhone using Magic
you dont need 3metre ramps. Mine are about 2 metres (rampco) and if i'm loading it on my todd I use a small hand winch and a strop attached to the headboard of the truck. The winch is the type you might use to load a small boat onto a trailer, it's lightweight and only cost me about £20. It takes me about 2 minutes to set up and get it onto the truck. I'll take a pic of the set-up next time I take the grinder out.
Thanks
a friend of mine has a set of ally ramps about that length he was on about selling , he used them when he had a 3ton digger and loaded it on his lorry
Read more
