  • Replies 125
Don't know. How do I find out Peter??
right click your desktop depending on your operating system i.e vista click personalize then go into display settings it should tell you it in there.
For xp I think its right click your desktop then click on properties and then click settings should then tell you your set resolution there.
1024x768
I had a look the issue I can see is on the home page where the right boxed sidebar is moving across over the classifieds in firefox and in ie7 it gets pushes down below sidebar. Is this your only problem?
Mine isn't just like it on the homepage, It's on every screen. Even the different threads. It has the banner running along the top of the screen with all the shortcuts on it and then all the posts are about half way down the screen, right after the adverts to the right. Hope that is helps??:confused1:
I did what you said but couldn't find the resolution. Sorry.
Tom
