woke up to this to-day
sandy2210
  • Replies 23
oh well after looking at it for an hour yesterday finally tackled it to-day first attached 2 winches to the stem just at the root one attached to landrover winch and tirfor to copper beech (the tree with the swing on)just to make shure it did not go back suddenly ,then cut a gob out of underneath the stem near the root then came down from the top leaving a hinge exactly as you would if it was still standing with a couple of wedges in from the top -then removed all he small stuff from the bit of the crown throwing it out of the way so I had an escape road clear by now i was getting worried that if the root did go back it would be heavyer than the l/rover (and its not mine) took the winches off and cut bits off the limbs till the root started to go back very slowly until the hinge broke and root went down where it was nicely rest as they say was easy
ps that wee squirrel was around all day
Way to go,nibble the crown back after dismantling the upper limb,take small pieces & you will know when its getting ready to sit up again,pole saw job keeps it safe.:001_smile:
Ditto above. Reduce all the easy to reach bits of the crown first in small stages then re assess. If you haven't a pole saw then a saw with a longer bar can be handy....
What you want to do now is get yourself on the Cs34,35 course. It does need 32 first.
A couple of ghillies at an estate over my way did it alongside me a couple of weeks ago. Great course and would have taken any of your worries away and given you the right ideas to tackle it. Well done for sorting it and thanks for the description and pictures.
