How long a bar on a ms460
normandylumberjack
  • Replies 20
I suppose it depends on the situation .As a rule most 460's in this area carry a 24" or what Stihl calls a 25" .It's a good combination of balance weight wise and power wise .
Usually and speaking in this area they don't normally get to a 36" unless the approachs around 100 cc's . I have on occasion however ran a 32" on both a souped up 038 Mag and an older 048 which is the same displacement as a 460 .Skip tooth chain ,no problem .
and an a stihl ms880 or a husky 3120xp with a 30 inch bar flys through the wood
No doubt but you should see one with a race chain a nine pin sprocket and a 16" bar .:biggrin:
Okay fun but not practical .A saw that size is designed for a 42" and longer .
Ha one of the reasons a large saw of that size will last so long is simpley because of the fact they don't get used that much .The novelty wears off pretty quickly if you lug one around all day if it's not neccessary to use one that large .Traveled that road a time or two .
  • 3 weeks later...
I want to know if a Stihl MS460 will run this size of bar, with gustto, in knotty oak, ash and elm?
It will do it, but not "with gusto". You'll need to keep the chain very sharp and be pretty gentle with it in knotty oak. If you can get a semi-skip chain that would be helpful. If you want "with gusto" get hold of a 660, or a big bit of old iron (075?) with a 36" bar.
