You won't get a seperate piston from Echo as they only sell a piston and barrel kit at around £150. You will also struggle to find a pattern piston as they are very scarce, so you could very well be looking at spending £150 even if you can get away with just fitting a piston and rings.
  • Replies 22
Hi . The key here is what Spud says "aluminium transfere " Don't just fit a new piston and rings without cearfully cleaning the pot . If you don't you will be back in the same boat almost at once . Good luck .
Like I said earlier- you can't just get a piston and rings anyway. Rings- yes, but a piston no. Never found one for mine when I needed it Echo don't supply a piston- only piston/barrel kit and no pattern pistons avaialble that I could find.
