So I have a mess around with a tether and I've come to this [ATTACH]107206[/ATTACH]
I dunno if it's because I'm using 13mm rope but there is a fair bit of friction when I release the hitch and its quite jolly as well
Good to see it being used, i use smaller hitch cord and less wraps like i used to use 2-3 wraps and 4-3 braids on a vt. 2w,4b and 4w,2b :thumbup1:
Steve, its great for reducing trees, takedowns are either as they both serve the purpose but think that drt favors more climber in that situation and obviously the mechanical advantage. :thumbup1:
For me im srt 95% of the time, just the advantages for me out weigh the mechanical advantage of drt, except weekends when im susan....:lol:
Ye the oc is very stiff to use I have got some Yale about the place il try with it
the softer the cord i found worked better, but make sure its heat resilient. Stiff cord seemed to occasionally miss bite even on drt.
Ye I know that from climbing on a vt. Will having 13mm rope make a big difference to the smoothness of the wrench?
sorryi miss read wha6t you were asking its better on 11-11.5mm ropes i found but in fairness should work the same on 13mm
