So i had a quick play using the lockjack, seems to work ok but really relies on the wrench biting in. I haven't had a long/challenging limb walk as im seeing how it work so safety is always first. I think the tether needed to be shortened up for use with the lockjack tho.
407684_306402882734201_125192177521940_848207_1702296114_n.jpg.b2646971637219cc4ac9522eeb5ecb64.jpg
Try using a clip instead of a crab to attach the tether that should reduce the length. I dont think you need a rated crab after all the RW is not rated and is only designed to add enough friction to allow the hitch etc to work SRT.
I've got a short link on my rw,the small eye is attached to the wrench then the big eye I larks foot onto the top of the lj.
As for non rated, fair enough with a hitch, as the hitch would grab if the krab failed, but the lj would be a quick drop!
got any pics mate of this set up?
You wouldn't drop but you would find it über hard to move it in true SRT mode.
Just with the bottom attachment? I haven't tried the lockjack on it's own on a single rope (nor do I intend to) but I have had a play with it on the ground srt. It seemed to pull hard to one side,as the attachment points are offset to the rope.knowing it would grab in the event of a wrench failure is good to know though! Cheers
To add to what Drew said, once you have a bit of weight under you, with either a chest harness-rig, or the lanyard over the shoulder (or "LOTS" as I'll coin it right here and now ;) )
Remember, you are not bound by the friction-laws that rule DRT, so weaving redirects is easy, faster and more efficient.
I can pull hand over hand with my RW rig tied to me either LOTS or via a chest harness for jaunt of up to say 10 feet straight up, more, say 20 feet or so if I can put my feet on limbs or the tree :)
Ok, I understand what you're saying but I find it hard to believe that this is easier than ascending on DRT.
After all, on DRT the standing side of the rope is helping to pull me up while I pull down on the running side. I use a Pantin a lot by the way.
I dismantled a Maple today and had to be very systematic as I couldn't damage the shrubs underneath. I couldn't see a single time when ascending SRT would have been easier, yet I do understand the SRT concept and technique.
Am I missing something or is it just a case of pros and cons?
