Not yet mate i was more thinking on the descending single line problem on a pole.
Oh Yeah i forgot about that,Looks Spot on then :thumbup1:
  • Replies 101
So I guess with this m rig setup you either dont use a cambium saver, or have to climb back up to take your cambium saver out? Seems a bit of a pain in the arse no?
Best if you have 2.The 2nd one will retrieve as normal and come back to you while the orginal one will still be there and your back into normal Ddrt.
Here's my M-rig configuration not tried it in the tree yet but runs smoothly on 2 pulleys at the anchor points.
[ATTACH]82511[/ATTACH]
That looks pretty smooth, is having that small green ring on during a climb going to get in the way, as you have to have it from the start?
I reckon you should just put that SJ back into one of your many kit bags and fish out the hitch-climber you know it makes sense:001_tt2:
On a side note those DB bags are truly awesome best arb designed kit bag i've seen so far.
