if it helps the grinder is a Rayco RG 1635 super JR , according to the info sheet it says that the grinder can grind to a depth of 11 inches , surely on a big stump you can grind 11 inches under ground
you can ,you go 11" down then reverse the grinder & start again :biggrin:
  • Replies 35
I ask what the area is going to be used for and then advise on the depth necessary.
I did a cedar tree in the middle of a lawn today and agreed with with the customer to grind the bowl to a depth of approx 8 inches below ground level, if it was to be a veg plot then I would have a different plan of attack.
The trouble is some times a customer will ask for the cheapest option and the spec will be to grind just below ground level, if they change their minds afterward and want to use the ground then they may well forget the spec required at the time and asume the operator would grind them out completly just for kicks :sneaky2::laugh1:
