  • Replies 26
At the risk of being blown out of the water by some 4x4 expert,your tyres are probably 205/80r16 and ive found the best allrounders over the years to be michelins.
Also reverse gear is quite high so if backing up any distance especially pushing a loaded trailer,just drop it into low range to save keep dipping the clutch.
Hope this helps.
the oil change interval on earlier rangers is 6k not 10k as some one stated earlier, they are a pretty reliable bus, if it's going to be towing the earlier ones have a tendency to snap a leaf in the rear springs from new but the replacements should fix the problem.
