Anyone ever used a caravan mover to manouver a towed chipper? Don't know why chipper manufacturers have not sussed this out by now. I don't need a tracked chipper but it would be useful to be able to move my towed chipper without having to get hold of a quad. Was thinking along the lines of a eurotech caravan mover but not sure if they are powerfull enough (or too slow).
We looked at it several years ago but thought then that it did not add value to a road tow machine for the costs involved. If you do a lot of work where you can get a machine but not a truck behind a house then a tracked machine is far better option or you buy something like a CS100 and push it about. Possible even a compact tractor and a tractor powered device is an option too.
You have to remember that a caravan isn't that heavy and these devices are not for "off road" at all.
It has been done and fair play to those have done it but as a mainstream "cost option" it did not pan out.
Edited by PeteB
What about a powered jockey wheel? I don't do alot off road stuff so thought a powered jockeu wheel with off road tyres might do lawns and stuff.
tried that but did not work
not enough weight on the jockey wheel
It would only work where I could of pushed it so sold it to a guy on here:thumbup:
  • 14 years later...
A repeat client, newly retired from a caravan dealership where he worked as a fitter/mechanic, took these motors off a caravan that had been in an accident.
In exchange for some tree work and firewood, I now don't need to pop a vein in my neck pushing 1000kg into my garage each evening.
Yet to try it on grass but I've a job in January where we can give it a Wang.
Just in case it doesn't work, my colleague will bring his 4x4 mower to tow it into place.
It this proves successful, I'll look at a more beefed up jockey.
I need to adjust a rubber air hose to give the control box under the hood more room.
I'll also upgrade the battery for a higher capacity one.
Edited by Ty Korrigan
13 minutes ago, Mick Dempsey said:
Nice.
I always feel the jockey wheel digging in on soft surfaces is going to be the big problem with that set up.
Yes, true, though I will drive it in reverse for the most part which will limit that and can open the infeed to lower the weight on the drawbar.
Jockey is due for replacement anyway so I might look at fatter model.
The original one fell apart very quickly and the current one is a design that folds up as you wind it.
Bit close to the truck and the winder has been hit a few times.
I'm sceptical about the longevity of the control box given heat and vibrations.
  • 3 weeks later...
O.K, reporting back.
So, it's been useful putting the chipper away and for positioning on hard standing and gravel.
Off road on a clients lawn, slight problem.
This is due to the rollers requiring more purchase when the tyres are slippery.
One roller slips a little so I'm constantly having to adjust the direction but it got into a garden and back out across a damp lawn without leaving a mess.
Saved us a long unhappy drag though so I still count it a success.
Now to get the the rollers repositioned or perhaps a meatier set of tyres...
  • Like 6
