wood burner choice
Logrover
Im looking for a woodburner on a budget, looking at the clarke small pot bellied stove for about a hundred. its to heat a small room in a cottage and only has to last a year or two. Need to speak to the landlady about bining the silly leccy fake one first! Wood is no problem and will just be run on it.
Thoughts :001_smile:
on of these slight seconds would prhttp://www.naturalheating.co.uk/slight-second-acorn-cast-iron-woodburning-stove-p-1280.htmlob be better
ive fitted on in my workshop plenty of heat
hmmm im not sure if its viable as the cost of installing will knock the arse out of it! i could easily install myself even with a liner etc but would this have to be checked by a builder and signed off? Some burners dont need liners anyway but i think id need the chimney smoke checked again costing! Its annoying as it will save lots since the house has all round leccy panel heaters.
So could i get the chimney checked if ok fit myself with a metal plate at the chimney base?? then get it checked?
I believe that if your landlord fits the stove then they have a duty to get it done properly. If you do it then you can do what people have been doing fine for eons with no problems.......do it yourself. I did the flue on my mains gas rayburn and when i moved out of the property the council had it checked and it was fine, and you are only installing a woodburner after all.
