looking for some pointers about a kohler magnum 16 on a stump grinder.its backfiring really bad i think the valves are needing reground but it isnt an engine i am familiar with is there any service and parts manuals available for this there is also a bit of wear on the throttle spindle i read somewhere that the governors were poor on these engines .cheers to any advice
If its on a chipper, they tend to do that, my Chippit 25 did it from new when you knocked the rev's down, apparently its the flywheel pushing the engine round.
We had the same engine put onto one of our old Howard Gems - brand new Kohler Magnum and it back fires everytime you drop the throttle back quickly. I wasn't that concerned, just need to go easy when we throttle off
i stripped it down to have a look see and when i lifted the head i turned it over and the exhaust valve lifts twice per two strokes once a fraction when the inlet valve is open and then it opens fully on the next stroke i think this is why it backfires so i dug into it further and there is part of the governor hitting of the bottom of the exhaust lifter does any body have any info on these engines
