What's on your bench today?
spudulike
You never ported that395xp of mine did you? Mate keeps wanting me to ask as it cuts so much better now!
I have a 576xpg (non auto tune I think) that keeps cutting out at the end of cuts, as soon as you let off the throttle. Does it more often when using half throttle. Really really annoying! Any ideas?
It runs fine starts fine, idles fine. Dies immediately at the end of a cut, not die slowly. 5-6 pulls and it starts again.
Know where I can get any big saws spud, 3120xp, 880 etc?
Your 395XP just had a good going over:thumbup: The 576 sounds like the carb tuning is wrong, possibly needs richening on the L screw but difficult to tell without seeing it.
No got 2-3 small problem with it
Oil pump don't work is the biggest one
I will have it to bits and have a look
The saw looks like its done very little work under the covers the paint work is like new
I'm starting to get a good collection of big saws
When you say oil pump, I assume you mean the automatic pump? You'll need to split the pump tank and replace the diaphragm :lol: but check the impulse line and the bolt to adjust the oil flow.
Have fun :lol:
Sent using Arbtalk Mobile App
Cheers for the pm eddy
Rite iv bin having a play yeh the chain oil pump the manual bit don't work have not tried it running
Now inside the recoil cover there is a bit of metal with small teeth if u follow the rod it takes u to the choke
Am I rite in saying the teeth with the bit of metal is a governor setting
