Did it have new crank bearings?
Hold the bus:blushing: no it didn't Steve , i think it's missing a washer :(image.jpg.ef06cf872e90ccaf6f5934f4b1ab9db7.jpg number 10 I thought that was part of the oil pump drive..... I'm a tube:001_rolleyes:
Hold the bus:blushing: no it didn't Steve , i think it's missing a washer :( [ATTACH]143489[/ATTACH] number 10 I thought that was part of the oil pump drive..... I'm a tube:001_rolleyes:
I was thinking male chicken:lol:
It is probably a thrust washer so very thin!
Looks like I did a good job then, got a mini typhoon coming out of it:001_rolleyes::lol::thumbup:
Quite slow really, would have thought blowers would be at least 10k rpm stock
Sent using Arbtalk Mobile App
Today's benchfull of saws: 201t, retune and sharpen, 088 sharpen, 2x ms460, one with a faulty stop switch, both cleaned, checked and retuned, one has a nasty kick when starting, so I'll have a good look at that, next was a 560 with a completely buggered chain, had to file the teeth down to half! And also working on a seized 200t, god knows why it seized, plug was a nice dark tan colour, but the outside of the cylinder is covered in crap, welded on good and proper too!
maybe the 200t heat seized due to all the junk stuck to the barrel..
chris
I think it was tbh! Anyway 2 more 200t's to look at, boggy pick up, low power, stalling on idle, both fitted with the 020 carb, any suggestions?
Clean them, check the meter arm height, and check the low screw is all good and clean. Pop test the carb. Also check the diaphrams are ok. (Yes I know I can never spell it properly)
After that, impulse lines, crank seals, etc.
