Not had much to do on the chainsaw front.
Got a mcculloch California in with a cream crackered coil. New one is £60!! Seems I cant get a s/h one anywhere so if anyone has a mcculloch part saw with a good coil I will happily buy it at a sensible price.
hahha yeah right. i would gie up on the landy if i had to do that.
for in a square inside. a nie big set of doors, not rollers but double.
yes enough to get a big trator in it.
pics when i open up.
nope as the ipad has gone. swapped out for a laptop. a lot better for work use.
anyway. on the bench is a titan multi tool in need of a primer bulb.
other than the usual stuff thats about it.
Been working on an MS150, it had a 5mm muffler mod so I did a few test cuts in this tune and then opened up the muffler to 8mm and advanced the ignition timing.
The mod is worth 7% gains across an average of three cuts, not as much as I was hoping but thats life! Would have been more interesting comparing with a standard saw.
Also got a MS362 in for a full porting, this looks like it has a bit left on the table, the exhaust can be significantly widened unlike the MS361. The uppers can be rolled back but almost nothing on the inlet as it is a strato engine and the piston hinders much widening of the port - possibly 0.75mm either side.
The lowers can be matched to the gasket and may open up the crankcase to get a bit more flow - a muffler mod should get this saw running with a bit more gusto:thumbup:
[ame=http://www.youtube.com/watch?v=k279fFMBmts]Stihl MS150 Muffler Mod 5mm - YouTube[/ame]
