What's on your bench today?
spudulike
Why do you have to hold it in? Is it faulty and weak? They are still available at about £22 as ive just bought 2.
I know where your coming from about using decomp. The 075 had a blanking plug which I soon changed hence 1 decomp, the other like your was weak and would pop out every time even if it didn't fire.
No, the 070/090 decomp has to be held in, it doesn't lock, they are operated by a piece of sprung metal
Sent using Arbtalk Mobile App
Got a pic?
Maybe they can be substituted? That's confusing, so you have to hold it in manually and listen for it to fire before releasing it? :confused1:
Edit
Just looked and a decomp for a 090/070 is only £6 odd + vat! Considerably cheaper than 051-075/076 range
Edited by wisecobandit
Got a pic?
Edit
Oh, once it fires you let go, the actual firing of the engine is enough pressure to shut it
That metal strip across the top is the decomp
JB-weld it? Or blue-tack?
[ATTACH]131939[/ATTACH][ATTACH]131940[/ATTACH][ATTACH]131941[/ATTACH]
Bit of jb weld and it will be good to go, :thumbup:
Said the small end had gone, :001_tt2:
Nice and easy fix then, new pot and piston. A few tests.
Looks like the pot had split. Could be an imperfection on it.
I'll buy the pot and piston and I'll pay you a fair bit too if you'll fix it!
Can you see the grass looking through the engine?
