we use a 2-3 tonne 4wd dumper thats had the skip removed and a tractor loader with pallet forks fastened on
works well enough but it's lifting capacity is only one cubic meter of split logs as any more makes it light at the back end and fitting a ballast weight is difficult as it's hand start plus could overload central pivot
  • Replies 41
I have an idea for a processor loader but not the time. I think an out front mower like the toro about 25hp. You see them about with decks trashed or missing. Can be bought for a few hundred pounds. Mount a loader and log grab on the front. Lift would only be about 200kg but enough to load a log deck. The machines come with hydrostatic drive and 4x4 and hyd pump. fast and agile
Hi Dylan
Did you choose to fit a loader instead of a forklift mast for any reason - like the little Benford forklifts?
Cheers
Steve
was originally going to use a forklift mast but couldn't find one at the right price in good nick
picked up the loader very cheap, has the advantage of being able to put a bucket on
Yeah,I can see that - did you use a rear loader or the normeal foreloader.
I think that you could mount some three point linkage pins on the dumper and fit either as required - look forward to the pictures
Cheers
Steve
