poisoning roots _
Dr.Green
Not sure where to post this but if its in the wrong place please move it thanks
Anyways , i have a beech tree to remove , the customer wants me to poison the roots as he is afriad they will cause problems , personaly i would rather not do this if theres is a possibliltiy its going to effect the surrounding area.
There are 2 vegtable patchs within 3metres and a conifer hedge that surrrounds the borders.
The stump will be approx 40cm across , ive quickly read about driling or making sink cuts around the stump the pouring in glysopate ????????
ive got a feeling if i do poison the roots it could all go wrong down the line and id rather have both sides of the coin when i advise the punter
any adive would be greatfully recieved.. cheers
Dear Doctor: IMO glysopate will not leach from the root system of the tree stump you have been asked to treat by your customer. I have treated tree stumps with the active chemical in the past with good results. Since the material smothers the root system or whats left of the tree to final soil temp. I would use and not have any concerns. When I have used said product in the past I make my cut as low to the soil level and carefully pour the material to the edge of the trunk 360 degrees. I believe the material is carried thru the Cambium layer of the tree. Never have figured out why one bores holes in the trunk?. Hope this helps.
elg
IME Beech don't tend to coppice well, so chances are it will not sprout.
I would wait and see if it does, if there is regrowth I would simple treat the growth with Glyphosate (sp) or if the owner simple keeps cutting off any regrowth it will soon give up.
i dont think this old dude will be wanting it ground out , cost wise -
quote the old man 'the roots are going to lift up my greenhouse even when the trees gone, i want it poisoned'
il look into the eco plugs and thanks everyone as usual, the whole process sounds alot simpler now. you have tought the doctor something , i shall pass it onto my patient's
How could roots cause problems when they are not actively growing and are beginning to decay? I don't poison roots because I don't want any runoff, especially neat glyphosate. I've only had a eucalyptus grow again, within a month it had put another small clump about an inch high. It was getting ground anyway. But most trees don't come back.
cut down many poplars lately?
