Hows the log sales going now
mendiplogs
You see so many tree surgeons websites claiming a log of 30% moisture is seasoned and ready to burn. Not according to the solid fuel association it isn't!
I can honestly say that I have only seen a handful of tipped loads of logs on peoples drives that were obviously seasoned well. Almost all are blatantly green wit hose unsuspecting punters then buying coal to get the green wood to burn.
Pressing a moisture metre on the outside of your logs is not a accurate way of testing a logs moisture. You need to split the logs and test it in the middle and only 12 month old wood will be double 15%. You can kid yourself your selling seasoned as I presume your sales depend on you claiming your selling "Genuine" seasoned logs.
I currently have about 40 tonnes of 18 month seasoned oak stacked and covered but its still 35% in the centre once split.
Once customers burn "Genuine" seasoned logs most don't go back to the con artists selling green as seasoned, and I am not insinuating your are a con artist !
For every "Genuine" seasoned log you need to burn four unseasoned to get the same heat output and of course a chimney fire down the road or corroded flue liner.
I know how to test for moister! Of cause it has to be split. I know a lot of log merchants in my area that sell good quality firewood that has been cut and split and seasoned in 12 months or under. How many log merchants can tie up 20k in cord for two years.
15% after 12 months split moisture level ? absolute rubbish
Its obvious all the fresh cord to instant seasoned log merchants are going to defend the practice, but fact is it can't be done in 12 months or less.
So what you are saying that wood cut and seasoned for 2 years should be nearing 10% or less ? and 3 year heat log moisture levels ?
timber felled by harvester and smaller diametre stacked or cut right into a windy site will soon loose a hell of a lot of moisture. and yes to check moisture levels you have to split with axe and test inside face
a customer of ours bought our logs at 110 a cube and bought to try a kiln dried cube at 170 the moisture was exactly the same at 20%
Sent from my GT-I8160 using Tapatalk 2
