i have the choice of two processors, posch 280 or hakki pilke 1x37. both similar priced, seen the 1x37 today and thought it was ok, going to see the posch next week but which do you guys thing would be the best to go for.
  • Replies 21
come on this is what you need
Good video but you would want some serious hydraulic power to pick it up and run it. No good putting that onto a 2 ton teleporter, just not the hydraulic capacity. Looks a good tool though.
A
Its turning half the wood into kindling. What happens when it gets near the end of the log looks like it drops a 2 ft length on the floor. Would be ok if you want big logs and dont mind alot of trash the cord needs to be long as possible with 8ft lengths alot of off cuts to deal with.
You're not exactly comparing like-with-like.
The Posch would be better built but it can only handle straight logs up to 28 cm in diameter using a circular saw while the Hakki Pilke 1X37 can manage 37cm logs with a 16" chainsaw.
just getting a s350 posch from jas wilson been looking for more than a year at loads of machines at shows and local demonstartors and this machine although not cheap does seem to tick all the boxes . i questioned various operators using different machines and it still came out with good reviews and also mr wilson is always been very patient and helpful at answering over the last year!!!!!!!! i do take time to make up my mind so yes posch seems to be agood processor or at least i hope it will be
