  • Replies 26
has been known to be tied wrong
some use the yosemity tie off but thats even worse if not tied correctly
DOES need a stopper knot
I find it easy to undo and use it when either using the other end of a rope or on a rope with no splice
probably get shot down for this but i dont like it,
too complicated to tie, and can be hard to undo, i use an anglers loop instead
I think that is the first time I have ever heard that about the bowline. I was taught that knot before all others as THE most basic knot out out there and THE easiest to untie. I would love to learn a simpler knot that is easier to untie. What is the anglers loop?
use them all them ,think it was the 1,st knott mi late dad showed me,
use them for all sorts ,lorry get a rope we an eye in :sneaky2:
My rope has an eye in mate but I use other end and tie a bowline on. Can't explain why but I prefer it to an eye:confused1:
  • 1 month later...
You sure you are tying it right??????
I almost always use it for endline knot except on my biners direct to harness.
Tied to pulley for secret weapon.
For rigging and running up the tree for rope walking or pull downs.
I usually add the Yosemite tie off. And on big loads, say off the truck to snap out a stump use the Mountaineering bowline
  • 4 months later...
One of the most useful knots in tree surgery, applications as noted above plus: if you need to join two ropes which will have a very heavy load applied to them, use a bowline bend; (two bowlines joining each other by the loops) Sheet bends, even when doubled will slip and be a pain to untie. A bowline bend unties without the need for tools even when having been winched upon.
