  • Replies 30
I agree had to have mine welded out once at great expense.
I've just ordered some new bolts for mine and change them every 5 blade changes
and also the torx bit, where can you buy them with out having to buy the whole torx set
C'mon lads
a bit of mechanics subtlety needed on these
If you put torx into extension on a long arm wrench
Jamb the flywheel with a bit of wood
Then
and this is the clever bit
as you exert pressure on the wrench
keep lightly tapping with a hammer( well get someone else to do this)
works a treat
Also helps if you clean out the torx with a sharp object first.
Also put copper grease on threads of torx bolt before fitting after putting in new blades
There you are
My simple( well maybe not so simple) solution to a TW problem
we've used the same torx bits now for about 20 blade changes
It tends to happen to some people more than others ;)
vs.
:001_rolleyes:
don’t forget the underside of the head of the cap screw
:001_rolleyes:
All the above plus tens of other techniques...
Top and bottom of it is you should not have to tap on the back of anything.
TW need to use a deeper headed bolt, not a shallow one. I even flatten the small dome on the end of the torx bit so the spline sits deeper
I know!!
Mechanics is frustrating specially when you've had a hard day/ in a rush/ it's about to rain.
I agree it would be great if TW came up with a simpler system but there you are
My solution works every time. Give it a go. :thumbup1:
Still having said that, I'd love TW to get back to us on this. With a reason/upgrade
Quote.
Thats about the top & bottom of it!
I've made a special tool where the torx bit fits in the bolt head, then you rotate the flywheel till the bit goes behind the case, the bit is the exact length needed to touch the back of the case and not let the bit ride out of the slot.
But there is very little helps when someone else has had a go and rounded them slightly.
My point here is, I have never ever, even slightly rounded the hex key bolts on my Bandit, I know you are supposed to change them, but mine are the original bolts and I have had my blades off maybe 40 times.
TW used such shallow heads there is a huge risk of a novice damaging them, whereas on my bandit, the hex bit would snap off before it rounded
