While we are on the subject of band saw blades I would like to pick the collective brain a little.
I am the proud owner of a pair of band saw wheels and blade guide. I took them out of a large Stenner resaw that was bound for the scrap yard. I intend building a mobile band saw using these parts.
The engineering part is simple enough the questions I have are about blade length and type. Clearly you guys with proprietary machines just order the appropriate part but where would I go to get a blade made to length
Is there a particular tooth pattern for green timber?
Is there a correlation between tooth pattern and blade speed and what sort of speed do I need to run the blade at?
Thanks
Andy
The blades are made up of saw strip cut from a reel and welded, so no need to worry about the size that your blade ends up.... Although it's obviously easier and cheaper for blade firms to make up a dozen or so bands at a particular spec.
I can't remember what blade speed is best, I think it differs slightly for narrow band mills (1 1/4 to 1 1/2in mills) and big old wide bands (3in upwards). Probably best to talk to Stenner, they are a helpful bunch, they will be able to give you an idea what the resaw ran at, it's best to stick to that I would think.
Tooth pattern (spacing) seems to be governed by the feed speed you want to work at* and the width of timber you are likely to cut.
What varies for differing density of timber is the tooth shape (profile) and mainly the hook angle- the hook is more pronounced for softer timbers and lessened for harder or mor difficult, but the feed speed then usually has to drop. On Wood Mizer machines I think they run something like 10 degress forward hook for softwoods, 8 deg for all round and 7 degrees for hard timbers and frozen logs....
*and that is governed by:
a) power available
b) thickness and rigidity of the blade
c) quality of finish wanted
  • Replies 21
Thanks
Andy
How big are the fly wheels? The ones on our Stenner 41 are 3' as are the ones on the Robinsons resaw.
I don’t have an exact measurement but 3 foot sounds about right.
a) power available
Power will be from a hydraulic motor so there will be plenty ‘O torque. The wheels are big aluminium jobbies so the bend radius will accommodate thicker blades, and a variety of teeth will cover different finishes.
I will give Stenner a call but I am sure the first thing they will ask is a model number, which is where it will get interesting.
Measure up the wheels, then Stenner will be happy... no doubt there's a rule of thumb for blade speed, might be a bit different for the newer pitless resaws, but the old growlers like the Stenner VHMs and Robinson EFT are probably all the same.
Brushcutter- the motor rpm will be there to suit the electric motor no doubt (1500rpm to 2000rpm?), then the revs will be geared down through the belting to give a much slower rev at the wheels. A 3ft diameter wheel will travel a blade 9.425 ft every time it rotates, so you'd end up with a blade speed of 14,000ft per min or 235 ft per sec if the wheels were driven directly at 1500rpm motor speed.
That's 72.5 metres a sec, which makes a chainsaw look pretty lazy.... :ohmy:
Stenner or one of the woodworking firms like Daltons would know what's required
  • 2 years later...
A wee aside "Jonny Maun/Mon?" was the alcoholic blacksmith who lived in a hovel cum blacksmiths forge very near Drenagh Sawmill, Limavady.
And brazed the big bandsaw blades for the sawmill.
And was apparently gifted at it.
This is if I am correctly recalling a morsel of info related by my father some 45 years ago.
When I idly asked "does anyone live there" as we drove past one day.
Marcus
so expensive for me to buy them now anyone made there own welder ?
can import the band blade in 100m reals for just over a £1 a meter so its defo worht wile any ideas ?
ricky
I cant remember where I saw it but there was a sharpening band welding setting serious machine for sale looked a complete steal if you needed one. It was either on here or one of the auction sites. It was about a month ago. I was tempted to buy it and I have no use for it and would not know how to work it. :biggrin:
