I'm collecting information about tree climbing saddles/harnesses to create a reference guide for all future saddle purchasers. I will share the results once I collect enough info. I've posted the survey at treebuzz.com as well and have gotten a decent response, but I'm hoping arbtalk will get me some more reviews on european saddles.
One saddle per survey please! You can take the survey multiple times if you have more than one saddle.
Thanks for your participation!
Please take the survey here: Tree Climbing Saddle Survey Part 2
There are often threads on here asking "which harness", I think that if your survey takes into account the height and weight then that will be a very good thing. a good saddle for a 190lb guy will probably not suit a 140lb guy. Ideally once completed climbers could put in their height and weight and see what harnesses others of their build rated highly.
Alex - Yes, after I made the survey I realized that I should have made 10 good and 1 bad. But it was too late, I already had too many surveys completed. Unfortunately I've already had to "correct" some of the surveys because someone would rate the comfort at a 9 and then there positive comments said "very comfy". Obviously they meant 2, not 9.
Tom - that is what I hope to do.
