Main line setup when chogging
nuttap2000
  • Replies 28
The problem with a single line and extra wraps on the friction hitch is although it will catch you you will be unable to descend without a figure of a 8 or similar descender below your hitch.
you need the figure of 8 or similar above ur hitch bro, as that takes out the friction that would of gone onto your hitch.
With your main line simply around the trunk how would it grip on a smooth pole? The solution I've been taught is to use a bowline to choker it off around the stem. This then puts you onto a Single line which your usual climbing system probably wont cope with (lots of slippages and possibly no grip at all). Simple solution is a munter hitch on a HMS carabiner attaches low on your harness, giving that extra necessary bit of friction.
Matt
