Write the address of the site your working on down so that in the event of an accident you dont end up refering to the site as where you reduced the Chestnut and the truck got stuck 2 years ago, because the emergency services wont have a clue what your on about.
If any of you have tips along the same lines then please share them :001_cool:
  • Replies 22
... And they didn't know where to find you after such a clear description as that :confused1:??? The fools....
Hope everything was ok in the end and nuthin too serious?
You should have a clear address,and if i'am felling in the middle of no where I use google maps to find grid reference.
Maybe that's a good tip but am sure there's men on here that would go into it deeper than that.
Sent from my iPhone using Tapatalk
You should have an 'emergency procedure' at least ?? especially if less than 5
eg
location/address
meeting point
nearest road junction
local hospital
access
4x4
air ambulance landing area
contact numbers
on the front seat/truck so if it does go pear shaped it is clear and concise as time may be a major factor and it will save anyone from getting into a flap giving clear and concise instructions
and if you are on your todd a worker should be in contact at set times to prevent unseen accident unnoticed
Nothing did happen :laugh1: Its just a heads up :001_rolleyes: .
If the pooh hits the fan having the address could save valueable time :thumbup1:
Aha, you were doing that hyperthetical thing :001_rolleyes: And there was me all concerned for your panicking selves!
I used to be a right pain when I met my contractors on site and I always asked to see their SS RA with all the relevant contact details.
Edited by janey
