Ropeguide 2010
Rupe
  • Replies 32
They do get stuck quite a bit, depends on how you set them and the direction you leave the tree from. So if its facing west and you exit east it might trap it self against the stem, but if you are in the right direction then thye are generally ok. Alos if your rope is in a straight line directly toward it then you should be able to flick it free, but if you have gone under/round branches/stems etc then if it gets stuck you have less chance of retrieving it.
So I was wondering if this new one is any better?
There are some tricks to help with retrieval but somedays nothing works! Lime trees seem to be the worst. I would try climbing on a pulley first to see how you get on with the lack of friction. It makes climbing on a prussik/blakes a bit harder on the elbows to start with.
Rupe, i started leaving the ropeguide a little bit longer than i normally did and that seems to have solved that for now, but i was getting very stressed with them getting stuck because of the pulley.
Yes slack is definatly better.
