  • Replies 25
On the subject matter. The bleeding possibly does reduce the uptake of fungal spores but there are probably many thousands that are sucked in as soon as sapwood is cut. The final cut is the one that allows spores to enter the system.
Whatever happened to the experimentation of mixing a fungicide into the chain oil?
However i think as long as we avoid doing the prune on a bright sunny spring day it wont be so bad, it tends to stop after 24-48 hours so doing it while the spring weather is on a downturn should be all we need to do in order to do what is fair.
We crown lifted a birch several years ago and it leaked sap for 2 weeks, to my knowledge its still alive and healthy [well as healthy as a tree can be after having its lower limbs cut off]
I've often thought that. But imagine if best practise becomes only pruning in the spring!
Sent from my Desire HD using Tapatalk
Isn't the bleeding-flushes-the-spores theory the whole reason for cutting Prunus spp. in late summer?
On this thread tho'.... cedar bleeds with a spring cut; true? I ask as I may have a deodar reduction coming up.
Guest Infinitree
More because the spores of the Silver leaf causing fungi-Chondrostereum purpureum are rife in the damp winter months- The wetter it is the more spores are released..
Yep hot dry days spores less prevalent, thats what I read somewhere............
Thank you.
