  • Replies 63
In breif...i climb from one line using two ring strops tied in prussics knots...anyone else?
Not sure what you mean by 2 ring strops. But i climb using both ends of my rope with a prussic. Never lets me down.
Thats the same thing, a ring strop is a prussik loop.
And yes you are a dinosaur, do you use a bowsaw as well or have you discovered the ms200.
Is your set-up simple because it works for you, or for some other reason?
I usually use one rope, VT, hitchclimber and a lanyard with grillon - it's simple but not as simple as yours.
penknife
