bought a ranger through private sale and steering wheel will turn 2 full turns to the left, but only 1,1/3 turns to the right
so i have a reduced turning circle to the right, which isnt noticeable when driving normally,but a pain when trying to park.
not noticed till 2 days after when tried to park in tight spot:thumbdown:
anyone got any sensible ideas on A) what the cause is B) how to fix it C) who to take it to???
thanks
  • Replies 34
get your front wheel alignment checked, you can do it yourself with a tape measure, check for bent steering components that may have been hidden by adjusting the alignment, park next to another ranger and compare bits to see if anything is out of place.
Probably when the tracking was set it was all done from one side.
When you are driving in a straight line is the steering wheel central.
yes steering wheel is central
