  • Replies 23
ive got a lewis winch and its good but havent used it much yet, it takes a bit of getting used to. I did get a capstan winch which is bad for tree work, i found it hard to keep pull constant on rope, avoid over wrapping rope and watching load, all at the same time. trashed a new polydyne lowering rope on first use!
I was thinking about 1 of the winches pro climber had demoing at the apf, all in one unit with honda engine so no need to get another saw. I think they are the same as the one used in the arbor trolley video.
I liked the fact you are not limited by cable length as its a capstone and has lots of mounting options.
The big skidding cone looked like it made life easier when dragging over stumps bad ground etc as less chance of a but end digging in.
Any body know how much?
love my portable winch use it to drag around 3 x 3 metre fire trays on bogs in the broads so should p*ss a few logs, the only advige i have is don't drop it in water whilst running, they don't like that....new engine job
