Anyone have any info for flail attachment mini digger
robert t
As title, looking for flail to fit onto volvo 2.7tonne digger. Sure i seen one at
APF but didn't pay much attention as wasn't some thing i thought i would need.
cheers, robert.
Having looked at the idea got to make sure you have the flow on the hydraulics to run it and the boom at same time !
Excavator Mounted Flail Heads
Home Page
when i looked into it it seemed they had to be set up to your machine hired one from a firm the head kept slowing down every time you tracked or used the arm even though the machine could be used on a 3 ton machine and it was on a 5 ton from what i found out you need to change the prority flow to the Auxiliaries and not the tracks and arm
you can still track and slew while using the flail just a bit slower and when the fllail is off the machine you can use the excavator as normal if that makes any sense?
I thought about it for my 1.5 ton. Flow rate is good (same guts as two ton machine) but I'm sure it'd be more cost effective to use an FS550. You can buy three of them to one digger flail too, no transport costs etc. The other thing is that there's bugger all reach on a 1.5 ton
Fair play on the bigger digger flails though, they look handy.
